1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83590 10/01/2007 12:08 PM | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | Got this question for you all:
Do you know the width of the rearend for a 1940 chevy 1/2 ton? Also, it seems everyone is putting an S-10 5 speed in their trucks, doesn't anyone put an automatic it them?
Danny
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | |
#83591 10/02/2007 1:30 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 59 inches wheel mount to wheel mount I suppose. I spec'd a 61 inch wheel to wheel for my 1940. That allows for wider tires that are offset to the inside by 1 inch.
Do your own measuring, and don't take my word as "law". A 1940 should have a box that is 48.5 inches wide. It also has about 11 inches of fender on each side. Using rims that are 7 inches wide, with 4 inches of backspacing should center you up pretty well in the wheel well. A maximum tire size would be about 10 inches wide...lets say a 255 series tire. Can't garrentee that you won't have any rub anywhere, so like I said take your own measurements and do your own math. I don't have my rear in the truck or the tires, or the box to see if it all does fit.
John | | |
#83592 10/04/2007 11:27 PM | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Why would someone want an automatic would be my first question. However many have done it. The issue is adding the cooling for the trans. I have seen custom rads, aftermarket heat exchangers, and a trany cooler bolted in front of the Radiator.
Your truck, your driveline - to copy a bad fast food commercial, "Have it your way"
#83593 10/06/2007 6:47 AM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Peggy, I have an auto in mine (39). Not much leg room, you would have to be a contortionist to be clutching all the time. | | |
#83594 10/10/2007 7:41 AM | Joined: Jul 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 70 | Peggy i don't know about the 40 but i do know my 37 gmc 1/2 pick-up's rear axle is 60 7/16" over all length. from wheel mount surface to wheel mount surface. and that is the orginal axle. hope that helps.Earl | | |
