4 members (Otto Skorzeny, Philipj, 60steve, Greg '46), 67 guests, and 4 robots.
Topics128,181
Posts1,057,151
Members48,464
Authorized Pest
Authorized Pest
Got this question for you all:
Do you know the width of the rearend for a 1940 chevy 1/2 ton? Also, it seems everyone is putting an S-10 5 speed in their trucks, doesn't anyone put an automatic it them?
Danny
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
59 inches wheel mount to wheel mount I suppose. I spec'd a 61 inch wheel to wheel for my 1940. That allows for wider tires that are offset to the inside by 1 inch.
Do your own measuring, and don't take my word as "law". A 1940 should have a box that is 48.5 inches wide. It also has about 11 inches of fender on each side. Using rims that are 7 inches wide, with 4 inches of backspacing should center you up pretty well in the wheel well. A maximum tire size would be about 10 inches wide...lets say a 255 series tire. Can't garrentee that you won't have any rub anywhere, so like I said take your own measurements and do your own math. I don't have my rear in the truck or the tires, or the box to see if it all does fit.
Why would someone want an automatic would be my first question. However many have done it. The issue is adding the cooling for the trans. I have seen custom rads, aftermarket heat exchangers, and a trany cooler bolted in front of the Radiator.
Your truck, your driveline - to copy a bad fast food commercial, "Have it your way"
Peggy, I have an auto in mine (39). Not much leg room, you would have to be a contortionist to be clutching all the time.
Peggy i don't know about the 40 but i do know my 37 gmc 1/2 pick-up's rear axle is 60 7/16" over all length. from wheel mount surface to wheel mount surface. and that is the orginal axle. hope that helps.Earl
