8 members (Wickedbass, MNSmith, 2-Ton, JW51, Maybellene, Hotrod Lincoln, 2 invisible), 88 guests, and 2 robots.
Topics128,042
Posts1,055,595
Helping build a 1950 Chevy pkup. Where the radiator support meets the frame, was or is there supposed to be any type of pad between the frame and the support, or does it just bolt down?
On my 58 there is a pad between the support and the frame. But i didn't see this truck get taken apart, and I didn't see any listing in a catalog I was looking at.
Yes, there is a pad. Actually 2 pads,evenly spaced apart on the mounting risers. It also allows for the addition of shims for alignment.
Drew
I haven't found a listing in the catalog I have. Any idea how thick it should be, or where to get it? Thanks
When I removed the support from my 50 there were 2 pads, one had a shim
...pic...
approx size 2 1/4x 2 1/4
3/16 thick
5/8 hole in center
I made my own replacements, as Drew posted you may need shims to get the body gaps right.
Funny thing is the Factory Assembly Manual shows only shims and spacers no pads.
Thanks, looks like I may have a new parts source.
I have a 1950 3600 and it looks like I have the pad for a 49 truck??
Here's a pic (if we are talking the same thing)
front bottom clip support.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Chevys of the 40's sells a body shim kit if you need them
...link...
