1 members (Leo), 104 guests, and 1 robot.
Topics128,049
Posts1,055,743
#83575 09/30/2007 4:30 PM
Junior Member
Junior Member
Hi all,
Ive got a 54' w/ a 235 and a "roch b" and I am curious what the preliminary settings for the mix scerw and the throttle screw should be.
-Owen
Have you, as the "always" first post suggest, tried a search for "B" Rochesters? As a past owner of two of them I know there are a ton of postings dealing with them. Pay close attention to "CarbKing's" posts as he is a "guru" on old carbs.
Riding in the Passing Lane
Make shure the float level is correct. Start with the mixture screw out about 2 turns from bottoming. Start the engine & set the idle speed about where you want it. Slowly turn the mixture screw in till the engines starts slowing down. then back it out to a point where it runs smoothest, usually 1/2 turn. Reset the idle speed if it has changed any. It,s good to go over the mixture adjustment after it has been driven awhile & is warm.
1972 Chevy c10 Cheyenne Super
Junior Member
Junior Member
thanks guys!!
-Owen
