| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Helping build a 1950 Chevy pkup. Where the radiator support meets the frame, was or is there supposed to be any type of pad between the frame and the support, or does it just bolt down?
On my 58 there is a pad between the support and the frame. But i didn't see this truck get taken apart, and I didn't see any listing in a catalog I was looking at.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Yes, there is a pad. Actually 2 pads,evenly spaced apart on the mounting risers. It also allows for the addition of shims for alignment.
Drew
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I haven't found a listing in the catalog I have. Any idea how thick it should be, or where to get it? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | When I removed the support from my 50 there were 2 pads, one had a shim ...pic... approx size 2 1/4x 2 1/4 3/16 thick 5/8 hole in center I made my own replacements, as Drew posted you may need shims to get the body gaps right. Funny thing is the Factory Assembly Manual shows only shims and spacers no pads. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Thanks, looks like I may have a new parts source. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I have a 1950 3600 and it looks like I have the pad for a 49 truck?? Here's a pic (if we are talking the same thing) front bottom clip support. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Chevys of the 40's sells a body shim kit if you need them ...link... | | |
