5 members (1955 1 Series, CuzzFuzz, Forty9, Hotrod Lincoln, thekid1950), 51 guests, and 5 robots.
Topics128,012
Posts1,055,321
Members48,419
#835382 03/15/2012 3:34 AM
When I bought my 48 chev panel van there was a resistor between the fuse panel and the ignition. Someone told me he thought that the only place the resistor would go is between the heater fan motor which goes to the battery. Is that right. Thanks for your help.
first48 #835440 03/15/2012 11:45 AM
What fuse panel are we talking about on a 48? Something or more than one thing is incorrect.
1951 1 Ton Completed
truckernix #835476 03/15/2012 2:56 PM
My '48 3100 has no such resistors, first 48.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #835498 03/15/2012 4:53 PM
In addition to what the two previous posts have said, I am assuming your van was converted to 12 volts. If that is the case, it would appear the PO thought that instead of using a resistor on each accessory circuit, he or she could use one large resistor at the source. I'm not going to comment on the merits of this idea, but you might think about rewiring. Also, there are a lot of discussions in this forum about converting to 12 volts that can guide you in the right direction. There is also a tech tip.
Good-Luck
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #835581 03/15/2012 8:41 PM
According to the diagram I have for that year of GMC there are two 20 amp fuses in a fuse box. Those fuses protect the tail lights and the stop light. There should not be a connection to the ignition from there.
truckernix #835995 03/17/2012 5:57 AM
If the wiring looks original I would consider a full rewire from the tail to the snout. Nothing is more frustrating than to have a lot of "mystery" wiring problems from an old harness.
~Jim
