| | | Forums66 Topics128,174 Posts1,057,049 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I am trying to find what will work on my 1 ton panel van. I put tires on my 17 inch split rims but I was having trouble with one tire. They are not easy to work on so now I think the right thing to do is put new rims on. I need to keep the rims at 17 inch because I have the new tires. I found some rims but when I put them on the hub sticks out and the chev hub caps will not go on. Are there other hub caps that will go on these rims or do I need to change the rims. Any help would be great!! This has been the hardest thing to do on this truck so far. Will be glad when I get this part done. Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Any GM, Ford or Mopar of the pre-metric period will work on the truck. I doubt you'll find any that will take stock hubcaps. | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I have the same rims on my 1941 1 Ton Pick up. What made them hard to work on?
I derusted mine, cleaned them up and put the new tires on myself after painting them. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | There are companies that will take your stock center sections and weld modern 16" radial rims in place of the original split-rim parts. | | |
