1 members (sron48),
124
Mod | | | Forums66 Topics128,164 Posts1,056,966 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I am putting my head back on and looking at the rocker assy. and wonder how the oil gets from the block( pg 8-10shop manual ) to the pipe in the middle of the rocker. It was oiling fine before the head went so I was just courious. Its a 1956 235 block 3837004 with a 1957 3836848 head and I have the 1958 truck manual.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year and size engine?
What year Shop Manual?
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Oh sorry, its a 235 1956 block 3837004 f56v with a 1957 head 3836848 l 16 7. in a 1959 3600. The old head was same casting # TThe shop manual is the 1958 truck manual.
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | same problem with 305! anybody? | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | My 56 has a tube behind the push rod cover. One end threads into a fitting just above the rear camshaft bearing. The other threads into a fitting right underneath the supply tube that curves over the rocker shaft. Mine uses a head bolt with a hollow center so the oil can pass through.
1956 Chevy 3200
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I was wondering how it got thru the head to the rocker assy. I didnt see a hollow head bolt on the reassembly . I am gona guess the oil comes into the head bolt at #2 torq position and travels up thru the bolt hole to a hole near the top of the head and over to the hole where the tube goes up to the rocker assy. Anyway when it went back together there was oil coming out the rocker assy. I was happy. | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Yes Thank you. That is how I thought it went. Nice pict. | | |
