6 members (Gdads51, 3B, 32Fordpuchoptop, Bill Hanlon, Otto Skorzeny, Joe H), 166 guests, and 2 robots.
Topics128,110
Posts1,056,246
Members48,437
#83451 09/26/2007 4:12 AM
JC
Offline
Hi All,
After owning my 66 C20 project truck, Ol Green, for the last year and a half, I committed myself to getting the old 6 cylinder running last weekend. It had been sitting since 99 or so. It would crank okay, squirt gas and have decent spark, but would not fire. I pulled the valve cover and saw stuck exhaust valves.
I pulled the head and unjammed the exhaust valves with my favorite pursuader -- a brass hammer. The short block looked fine, but the pistons looked really small, about 3.5 inches diameter. The stroke seemed short, about 3 inches! I had believed that the motor was a 292, or at least a 250, or possibly even a 230. I checked the numbers on the head and the block -- it's a 194 ci!!!!!
My question: Did GM offer a 194 in 66 c20's??? I imagine someone way-back-when could have put it in. Since it's a bit worn, a found a ready-to-go rebuilt 250 64 to put in so I can get it on the road and send in my progress to the gallery!
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
#83453 09/26/2007 5:14 AM
Former Workshop Owner
My sister had an old Chevy II '62 Nova that had a 194. I doubt that your engine is original.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#83454 09/26/2007 12:15 PM
JC
Offline
I already triple checked the numbers, bore and stroke, but thanks for the advice! It is definitely a 194. It's almost ready to come out as I plan on swapping it out with the 250 this weekend.
JC in KC
#83455 09/26/2007 4:55 PM
Based on what I have seen, people will put anything in a vehicle to keep it on the road, it probably didn't have much power in a C20. Of course someone may have sold the PO an engine and told them it was a 230 or 250.
Fred
#83456 09/26/2007 5:35 PM
Well you bought your truck from 4-5-6 Chevy. You are not the only guy that got a bad supprise buying an engine from him.
55 Cabover
#83457 09/26/2007 7:03 PM
The 194 was only used in Chevy 2/Nova and as a base engine in the '64/'65 Chevelle. The only truck use it saw was in the early Chevy Vans from the mid-'60s.
Bill Burmeister
#83458 09/26/2007 8:59 PM
Riding in the Passing Lane
Most 194,s came from Nova's & had the oil dipstick up by the fuel pump. To put one in another application you had to drill a hole in the rear portion & use the oil pan from the other engine. They were very sluggish.
1972 Chevy c10 Cheyenne Super
#83459 09/26/2007 10:05 PM
JC
Offline
The oil dipstick is gerry-rigged, so that makes sense. I just as soon not be sluggish! Thanks!!
JC in KC
