1 members (baldeagle),
98
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | I just got my front fenders back from being blasted. There was a lot of bondo on them. I had them take them down to bare metal and this is what I ended up with. http://img833.imageshack.us/img833/3788/img5069r.jpgMy question is these holes had just been bondoed previously. Except for the holes the fender feels solid. How should I repair this? Should I use body solder to fill the holes? Should I cut in a patch panel or should I get a new fender? Thanks | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Looking at the various high spots/peaks showing on the outside, it appears there still exists quite a bit of pitting on the backside that, although has not broken through yet, the sandblasting from the backside highlights the extent of the pitting damage to be quite extensive. I think to fix that particular fender, it would require new metal in order to be a more permanent repair not requiring attention a couple/few years down the road. Looking at the amount of work the repair will require, I think realistically you should look for a new fender or a solid used replacement. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | I agree with Robert. That said, if this was a budget repair, and most of the money was spent on the cab repairs and little was left for the fenders. The fenders could be changed latter as money became available, painted to match, etc.. One way to fix this area would be to coat both the inside and outside of the areas with an epoxy based resin/fiberglass, like WestSystems, as opposed to a polyester based resin that may not hold up to the expanding and shrinking of the metal in the heat.
....David
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You're going to need new fenders. Some quality fiberglas filler work would get those going for the short term, but long-term, they're dead. I'm going to guess that the lower edges are toast, too. If, somehow, the normal lower edge rust spots are all OK, you might be able to find some fenders that are rotted at the bottom but solid where you have holes. Unless you're doing the welding yourself, it would likely be much cheaper to find new fenders, though.
| | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Actually, If You repaired the area with all the holes in it, the fender will break out with rust in another place just as bad.. You will save time & money to buy different fender(s)... | | | | | Joined: Feb 2012 Posts: 8 New Guy | | New Guy Joined: Feb 2012 Posts: 8 | I'm No body guy but if you do decide to repair them I would stop bye your local powder coat shop and try to score some iron phosphate easy to apply awesome rust pervention when used properly and easy process for the reward
A nut among the bolters sure ill like it quite well here.I enjoy the 60-66 "iron" I like the gmcs,chimys,chevys regardless these trucks rule! Mine 63 gmc fleetside long bed. Custom cab 3/4tfirst truck<being restored  62 chevy short bed fleetside 1/2t
| | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | I was afraid of that. I have another fender that was hit in the front. Anyone suggest a good source for a new fender? I am finally starting to make some progress on the truck but it is taking so long. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Check you Private Messages
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Sometimes dents are much easier to fix than rust. Any pictures of the other fender? | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | lol i would put por15 on the inside of the fender it uses the rust as a binding and dosn't remove any metal ppl are too quick to just say "get new fenders" not all of us have deep pockets
1937 1/2 ton
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | POR-15, If I remember correctly, they have some that is designed to fill small holes and thin areas.
I do all of my fenders (inside) with POR-15 anyway... i'm 10 years in on my 39 Pickup and there isnt any new rust.
