4 members (Sjm, TexasJim50, Chris_Welch, 1 invisible), 103 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
I have a T5 from a '91 s10 with electric speedo drive, so today I went to the local Pick&pull and got an electric speedo from a '93 s10. My question is how do I hook the electric speedo up, in the pic there are 8 prongs on the back of the speedo. 4 are for the speedo and 4 are for the odometer. I am assuming the 4 wires are power, ground, 1 wire going to the trans sensor and 1 wire coming back from the trans sensor. If that is how it is, how do I identify what wire is what? or if that isn't the way it is how do I find out what is what?
back of speedo
1938 Gmc 1/2 ton
you're missing the DRAC module. hooks up in between the sensor and the gauge. on the S10 its a white box bolted to the same bracket as the computer
50 chevy 3100
cool thanks I guess I get to go back to my favorite place
1938 Gmc 1/2 ton
