8 members (1955 1 Series, Otto Skorzeny, KEVINSKI, Lostbuthaulinass, Peggy M, tclederman, 2 invisible),
92
Mod | | | Forums66 Topics128,142 Posts1,056,478 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | On my '65 C20 the only rot on the grille is on the ends which curve around the headlights (they look like parenthesis). These look like separate pieces which could be replaced but I have never seen them sold separately in LMC. Does anyone know if this is the case and if so what they are called?
1965 Chevy C20 Stepside
| | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | Can you take a photo of what you are talking about? If you get a photo shoot me an email and I will try to help.
65 K10 Longbox Fleetside Big Back Window Custom Cab 65 K10 Flatbed Old School Parts 60-66 (208)946-6173 [email protected]
| | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thank you. I will do that. Rob
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The grille shell is one piece. The bezel attach to the face of the grille shell and the mounting brackets, buckets, trim rings & headlights are attached behind the grille sheel, via 4 rivets. There are no replacement parts for the grille shell, itself. In lieu of trying to cut out the rust, weld in new metal, top-dress the repair, prep, prime & paint, it would be more economical to replace the grille shell. Check craigs list or the Truck Parts For Sale forum here and post an ad on the Truck Parts Wanted forum on this site.
We have them also, but the shipping will be as much as the grille shell.
| | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thanks Tony. I think maybe what I am referring to is really part of the fender. I have seen some fenders on Ebay with this part attached. Rob
| | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | I got to thinking about you decription and was wondering about that. It looks like a separate peice but is actually spot welded to the fender. It would be available from LMC or one of the other parts catalogs as part of the front half fender replacement piece. Hope this helps Lyle
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Yes the surround area that "frames" the grille is a 3 piece affair. The upper and lower are all part of the grille support panel, and the right and left are part of the fender. Here is a link to a diagram that should help: http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=19
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The transition of the front fender, to the grille support, is all part of the front fender. Likewise with the area, it touches, at the grille support, is part of the grille support, itself. I don't recall, off-hand, if the front fender half patch panel, includes the depressed area, that meets the grille support.
| | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thank you Lyle, John, and Tony. From what you all say maybe it would be easier to repair the rust areas on these parts with some fiberglass. It is just difficult to reach in there next to the headlight to work on it. Rob
