0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 10 New Guy | | New Guy Joined: Feb 2010 Posts: 10 | I need to get my 2001 diesel (trailer towing) truck aligned, and the man I like, Gary Raley,closed his shop for the time being do to illness. Does any one have a good place to recommend? My problem I believe will require somebody with some moxie.
S.A.R. member, Thomas Stone chapter, southern Maryland
If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man. Mark Twain | | | | | Joined: Mar 2007 Posts: 4,216 Moderator | | Moderator Joined: Mar 2007 Posts: 4,216 | Ask in the sidelot, ODSS. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Can't help Dave.I will be watching for the recommendation because I need an alignment as well. HB | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Dave -- Try Big Ed's in Leonardtown (The tire place on Rt 5 just this side of the Fairgrounds light -- 301-475-2929). He's done two of my modern drivers (including the Cummins truck) as well as the 9500. He also handles big truck/multi-piece rims without fuss.
If he doesn't want to do it, try Sensenig's Garage on Parson's Mill Road (301-475-5171) or Billy Cusic in Clements (301-769-2211).
Regards to all -- John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Dave, if you still need the alignment, Gary Raley isn't open every day, but works semi-retired now. Call the number, leave a message.... | | |
