| | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Anybody know of a FLAPS or supplier that sells 3-prong socket without the wires for a '54 headlight? Also need the female terminals that snap into the socket.
I'll attach my own wires from the socket through the braded conduit to the terminal boards on the inner fenders.
Spliced wires will not fit inside braded wire conduit, and I don't want a splice inside the bucket.
>> Or ... do you know how to remove the female terminals from the socket so that I can reuse it?
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Tiny - I apologize for not responding sooner - I ended up using my old socket. I clipped the wires fairly close to the socket and slipped the new loom against the splice. Thanks for taking the time to search and find a socket.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks for the good intentions Denny. The splice inside the headlight housing worked out OK. The socket was not original. I'm not sure the terminals would have been very easy to remove. The wiring harness was installed by a previous owner. The wires are not the original wiring colors so, no need to try to be perfect. I followed some of your posts regarding your headlight rebuild. They really look good. Got a question - what is the lithium grease for on the back of your buckets? Does the grease allow the buckets to scoot up a little higher inside the housings? My buckets sit too low (toward the ground) in my housings since I refurbished them. See this thread. FYI - I moved the spring to the lower hole in the bucket as Alvin recommended, plus I cobbled some othe "fixes." It helped a little but the bucket still sits too low. Any suggestions? Next - gotta aim them. Will you give me the link to your post on headlight aiming?
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Headlight beam adjustment ....link.... Fig 57 | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks, Gus - Geeze, I shoulda known to look in my Shop Manual. Guess I was too frustrated just trying to them mounted to think about looking in the obvious location!
In fact, I haven't even checked the Manual for my mounting problem. Who knows - maybe I'll get some GM Devine guidence.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Both of my original units had that smear of black graphite grease on the mounting ring when I disassembled them. The grease was applied at the factory when they were assembled at Guide. I assume it was to allow the headlight mounting ring to float in the bucket making for a smooth adjustment without sticking. My adjustment was very precise and smooth, I could place the beam exactly where I wanted it.
As Gus pointed out, I taped together a couple of very large cardboard cartons that my tool boxes came in and laid out a headlight aiming screen on it just as the manual described.
The off center problem has to be one of two things, either the vertical adjustment screw is all the way out at it’s limit, or the trim ring isn’t dropping into the slot because of the way the clip is fit into the ring as Gus and Alvin described. Those clips are notorious for being misshaped.
I would leave the spring in the upper hole as it was from the factory and focus on the clip. DG
Denny G Sandwich, IL
