2 members (moparguy, 51sub), 103 guests, and 4 robots.
Topics128,070
Posts1,055,892
Members48,428
#833064 03/07/2012 3:47 PM
They dropped the plug to save a few pennies. I know you don't need to change out the fluid every 3,000 smiles but...
Has anyone drilled out and inserted a plug, even one with a magnet to draw filings?
~Jim
You can also buy an aftermarket pan with a drain plug already installed. Kits are also available from FLAPS to install a plug in your pan.
there was time maney;maney years ago,in atcent times(the older i get the worse i spell)they not only had drain plugs in the pan ,they also had a drain plug in the torque convertor.theyremoved the drain plugs so people would drop the pan and change the filter when serviceing.
Some o.e. pans had drain plugs, the TH350 in my '70 GMC C2500 does.
BC
1960 C60 pasture art
maybe i should delete my post
No need.
~Jim
