0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#832940 03/07/2012 3:58 AM
1 Offline
About a month ago i started my 216 up. Well i decided i would go ahead and put the radiator on and let it run for a while. So i put the radiator support and radiator on (just frame and motor at the moment). I Filled it full of water and noticed that i couldnt find my radiator cap.. So i went to town and and when i got back i noticed that the water pump is leaking from the bottom right by the mounting bolt. Is this a pump issue or gasket issue.. Im using my old pump but have the new gasket on. Do these trucks have a weep hole like the new ones do that leak water when the pump is bad? I looked at the pump while i was putting the motor back together and it seemed to be functional.. Anyone else had this problem?
Thanks!
Daniel
1953 Chevrolet 3800 Stepside
Riding in the Passing Lane
There is a weep hole in it. If that is where it is leaking then you will need a new pump. If it is leaking around a bolt or the edge then it is a gasket problem. You may have to use a inspection mirror to see. It is common for a pump to start leaking after it has been setting for a while.
1972 Chevy c10 Cheyenne Super
Here's how the underside of the leaking water pump on my '54 235 looked. I'm replacing it with a new one from NAPA.
- Lonnie
My '54 3104
1 Offline
Thanks for yall's help!! Finally cranked it and ran it for a while. Ran good and didnt over heat. Although the more i ran it the leak showed it self.. Its now pouring from the shaft.. Time for a new one..
Daniel
