1 members (Gdads51),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Hey folks.
Got a 59 with a leaking pinion seal. Installed all new gears bearings and seals. I put a new pinion seal in it being that there is a chance I may have messed up some how the first time. Second time around I still have a leak. Is there a part number for a new yoke or maybe a different yoke and seal I can run all together?
Thanks for the help. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the yoke is worn where the seal runs you can install a speedi-sleeve on it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Very true. Anyone know were I can get a speedy sleeve for this yoke or the part number for the yoke So I can see what I can find.
Thanks Dave for the imput | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any NAPA should be able to get the speedi sleeve for you, don't think you'll find the yoke in the system
Bill | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Go to the SKF interchange page. SKF Interchange Input the GM part no. for the seal in the search bar and the product data sheet for the SKF seal will list the speedi-sleeve no.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you do want to find a NOS yoke it fits 1955-62 1/2 ton, and 1955-64 full size pass.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Thanks for the link harold. Went to napa and got one ordered. P/N: 99170
Thanks again
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Installed the new sleeve today. Works great. No more leaks. Now my wood bed is clean of oil. Thanks to all stovebolters for your imput
