3 members (KEVINSKI, Tom McGrath, 59 fleet), 110 guests, and 1 robot.
Topics128,034
Posts1,055,552
#8325 06/17/2004 4:19 PM
Junior Member
Junior Member
Hey all!
I'm a new guy with a '67 C20 327/400TH (hope it's not too young) anyway, I'm thinking about swapping the TH400 for a TH700R4. Anybody with that experience? I just checked out your forum today and it looks like a fun/informative place.
If I'd known I was gonna live this long, I would have taken better care of myself.
#8326 06/17/2004 5:19 PM
Welcome aboard, CrashBob. I haven't done the swap, but do know some about it. The TH400 is about 4" longer, so the swap requires the cross-member to be moved and the driveshaft extended. For info on the trannys http://www.novak-adapt.com/knowledge/transmission_gateway.htm
If you don't get all your questions answered here, you might try the 67-72 board. http://67-72chevytrucks.com/vboard/
But there are some sharp people on this board.
From a cornfield in central Nebraska? I've probably driven by your place. smile
Fred
52 3600
69 C-10
#8327 06/18/2004 10:48 PM
Junior Member
Junior Member
Thanks FredT
Who you workin on airframes for? I'm engineering for Hamilton Sundstrand(used to be Sundstrand Aerospace)in York. I went to the sites you suggested and think I can get some help there.
#8328 06/18/2004 10:55 PM
The 700 is a considerably lighter-duty box than the 400, but it's got overdrive and a lockup torque converter. There is a modern, overdrive-equipped model of the 400, don't remember the designation, but I think it's computer-controlled, and it's a tough swap to make. GM uses it in their motorhome chassis, behind the 454 engine.
#8329 06/19/2004 4:56 AM
Jerry,
I believe the later transmission you're talking about is the 4L80E-and yes, it looks physically identical to the TH400. Until you see all the wires hooked up to it... :o
Actually, a 700R4 can be built pretty stout, or you could just buy a complete performance rebuilt one from B&M or other such suppliers. They also have available electronic control modules to allow these newer electronic transmissions to operate properly as a "stand alone" unit-i.e. not connected to an engine control ECM, allowing use with an older carburated engine.
Crash, if you're on a budget and not racing or doing any really heavy hauling, a rebuilt 700R4 with some tweaks and upgrades should work O.K. for you.
Welcome to The 'Bolt, BTW. This is a great place to find out lots of info on these old GM trucks, glad you found your way here. smile
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
