7 members (baldeagle, Hanks custodian, Guitplayer, Otto Skorzeny, Maybellene, Hotrod Lincoln, 1 invisible),
43
Mod | | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Hey all. Still planning this project and have another question. Going with either a 700r4 or 200 4r. Wondering if anyone is running either of those and what ratio rear you're using? Thanks. | | | | | Joined: Feb 2012 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 70 | I thought you were keeping the factory automatic? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think the 700R4 is preferable .... I've got a 700 with a stock 3.90, keeps the pulling power and gives good highway speeds at lower RPM with the OD
Bill | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Joseph, I've got 2 54's ones a 3 speed column shift. Way too much stop and go here in Miami plus left leg gives me problems occasionally (broke it in 84). | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It all depends on what engine you are running & somewhat on the diameter of the rear tires. Either of those trans. are good choices. The 700 r4 is stouter & the 200r4 is lighter & shorter. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Wrenchbender, I'll be using the 235 with cam, headers and intake or a 261 (if I can locate one). | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Red58, what engine are you running? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The stock ratio ought to work good with either one of those o-drive automatics. It takes some special adapters to put them behind a 235. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Wrenchbender. Thanks for the input. Will prob use Langdon's adapter to make it work. Hope to find a 261 to put in. Either way will need to adapt the automatic. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | 4.11 with the 700 gives a 2.88 final in OD and the 3.90 gives a 2.73. Great road gears for an empty truck although a 261 might be able to pull a light load geared that shallow.
Evan
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I've had an 85 Chevy K10 with a 700R4, a 95 Blazer with a 4L60, and currently an 04 Trailblazer with a 4L60E. They all had 3.42 gears, and I'll tell you that they ALL needed steeper gears. I wouldn't use the 700R4 or 200 4R, without at least a 3.73 rearend especially in an old bolt. I know the 261 has more torque than a 235, but you still are only going to have 150 HP max. You would probably be happiest with a 4.10 gear.
If you go the 700R4 or 200 4R route, do yourself a favor and get a shift kit from Transgo or Superior. It'll be well worth it. A better 2nd gear and OD servo will always help too, it'll help hold the trans in gear better and help with the "engine flare" that both of those trannies are known for. | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thanks. I was sort of thinking the 3.90 was what I wanted. Good to hear I was in the right ballpark. Now just need to figure out which rear to look for. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The easiest swap is a '55 first series. Be sure to get the springs too. It will bolt right in like it was made for it. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I have 3;73 gears with a 700r4 tranny. It works great, lots of torque, and great gas mileage on the highway. I am running a 350 zz4 crate engine making close to 390 hp and I get 21 mpg on the highway. Sure worked out fine for me.
| | | | | Joined: May 2010 Posts: 30 Shop Shark | | Shop Shark Joined: May 2010 Posts: 30 | I have a 700R4 I plan to connect to a 350 and have a Firebird rear end (2:73). What do I need to ensure the 700 operates properly -- a shicft kit or electronic switch of some sort? Where do I find them? Thanks for any help. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Talk to the guys at Bowtie Overdrives. They can help you figure out what you need. I'm a little worried about your axle ratio choice. If you're running 28.25" tall tires (e.g. 225/75R15), then your 60 mph cruise in OD will be about 1360 rpm. I'll bet that's too low for your motor's torque band. I think you'll be better served with a 60 mph cruise rpm in the 1800 - 2000 range. regards, Leon | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I agree the 2:73 is to low for the 700R4 | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | A 3:42 or 3:73 works good. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If you have a pre-92 700R4 or 4L60, You'll need a TV (kickdown cable) connected to the Carb. You'll probably want to get a torque convertor lockup kit too. On a side note, If you get a Transgo NOYOYO shift kit, you won't have to get the lockup kit. It has a check ball and spring kit that lets you run the transmission without the lockup function. I would also recommend a transmission cooler. I would stay away from the 2.73 gears. You'll never have enough RPM for the overdrive to function properly. Go with 3.42 or lower, preferably a 3.73 or 3.90. | | |
