3 members (GRNHydra, Tiny, Wayne67vert), 86 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#83158 09/20/2007 3:45 AM
7
Junior Member
Junior Member
7 Offline
My truck has a 454 and it gets hot wether I'm on the hiway or in town. I've put a new thermostat in ,i have to 10 inch electric fans pulling air and flushed the 4 core radiator. I dont think i have a head gasket problem, that would be very clear. Water pump maybe?
#83159 09/20/2007 4:03 AM
72 chevy 4X4,
I vote for the radiator. If the radiator is plugged with mineral deposits and hard crusties, nothing short of a professional rodding or boiling will clean it.
For the water pump to be the culprit, its impeller would have to be rusted almost completely off.
Stuart
#83160 09/20/2007 4:22 AM
I too say have the radiator professionally cleaned.
Also check your timing to be sure it is right.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#83161 09/20/2007 4:59 AM
What year is the motor and what do you mean by hot? If this is an injected motor with a computer running normal might be hotter than you expect.
#83162 09/23/2007 3:10 PM
Junior Member
Junior Member
Quote
I also vote for servicing the radiator.
Other contributing factors could be:
No shroud on the fans can cause overheating in stop and go traffic.
At highway speeds the most common cause of overheating with modified big blocks (even a RV cam will do it) other than a faulty radiator is the water pump/intake manifold bypass not leaving coolant in the radiator long enough to be cooled. I block it off and use thermostats with two 3/16" drilled holes for pressure release.
Last but not least are quality of pressure caps and thermostats. It's not at all uncommon to get defective parts in either one.
#83163 09/23/2007 3:18 PM
Junior Member
Junior Member
Quote
Agreed. A friend with a 502 in a Nomad with aftermarket gauges thought he was having overheating problems because it always ran over 210°. The computer has the engine running at 220° for emission purposes.
