| | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83107 09/18/2007 8:40 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | I was wondering if any have had to modify the brake shoes to get this bar to work on new brake shoes? I have just finished installing all new lines and E cables (1959 1/2 ton pickup )and the bars where not there but I found them in the glove box so not sure if they are orginal or not. But believe they are and the brake shoes may not be correct as I am reusing the ones that I removed and not sure if they where installed correctly to start with as the E brake lever is attached to the short pad just wondering if any of you guys had encountered this problem and what was the fix? Thanks | | |
#83108 09/18/2007 8:49 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Focus, the "E" brake arm should be attached to the shoe with the longer lining [secondary shoe], as far as wheather or not you have the correct spreader bar, pictures would help a lot, hope that helps. | | |
#83109 09/18/2007 9:30 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are probably the right bars if they were in the glove box, but check your cables. If the cables are stuck or adjusted up too tight it will be difficult to put it all together. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
