2 members (FishinToms53, Hotrod Lincoln), 128 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#83107 09/18/2007 8:40 PM
I was wondering if any have had to modify the brake shoes to get this bar to work on new brake shoes?
I have just finished installing all new lines and E cables (1959 1/2 ton pickup )and the bars where not there but I found them in the glove box so not sure if they are orginal or not. But believe they are and the brake shoes may not be correct as I am reusing the ones that I removed and not sure if they where installed correctly to start with as the E brake lever is attached to the short pad just wondering if any of you guys had encountered this problem and
what was the fix?
3B Offline
Hy Focus, the "E" brake arm should be attached to the shoe with the longer lining [secondary shoe], as far as wheather or not you have the correct spreader bar, pictures would help a lot, hope that helps.
Riding in the Passing Lane
They are probably the right bars if they were in the glove box, but check your cables. If the cables are stuck or adjusted up too tight it will be difficult to put it all together.
1972 Chevy c10 Cheyenne Super
