3 members (k2handyman, Youngin' Tut 59, 78buckshot), 74 guests, and 3 robots.
Topics128,030
Posts1,055,418
Members48,422
Page 10 of 10 1 2 8 9 10
Messy fab table. I think 3-4 of us used it today to make various projects. I mostly sneak in before or after shift!
I believe I figured out how to set my "halo." Wish me luck! I'm going in!!
Pics to follow, if I can mange some time today!
Well? I didn't manage any time. With all the honey-do's before my vacation week and throw in a little pre-prep for a corporate photographer visit Monday and a CEO visit the following Monday, it just ate up my day. They sure do get all excited about electric trucks and stuff. Me? Just another hunk-a-junk with four wheels and a corporate logo that I have to work on. Doesn't make a difference if its a small sedan or a 45 ton crane. So about all I got done was to fit the upper half over the bottom half. This while also making a Ford to Chevy thermostat adapter for a 90 degree swivel so I can route the upper radiator hose around a blower drive for a 302/'40 Ford I'm working on.
Got tired of the broken speedometer on the Burb. There is too much drag somewhere in the system so the drive gear keeps popping off the output shaft on the 700R4. I've tried new cables, different VSS drive, 90 degree drive to take the sharp bend out of the cable, etc. So I've updated to a GPS unit. No more firewall penetration with a drive cable, also. I'll need to make a dash adapter out of some aluminum. It'll be fun as I haven't used the lathe in a minute. I ordered the speedo with high beam and turn indicators. I'll need to wire those in but it will be a nice add. Maybe now I won't have people tell me "Your blinker is on." when I park the thing.
Also, while I'm in there, I can update my idiot lights. "Charging" and "Check Engine." I used the throttle and choke cable holes for those when I first built the thing. Just simple little lights I made fit with some washers. I found some lights that should fit the holes nicely and actually tell you what they are idiots for! I also got a "Parking brake applied" light. So maybe I'll work on a switch bracket somewhere in that system so I can have one of those indicators, too.
I've been using the Burb as a daily driver for the last month and a half. My wife's new Denali got tagged in the rear. I wanted to have fixed right so I sent it off to the body shop. Plus the shop was able to get a little more fixit money out of the offending driver's insurance company. So, while that is out of action, I loaned her my daily driver. Which means I got to drive the Burb. Spending more time in it than just the occasional drive or car show helps you put a finger on things that can be improved. Body and paint is on hold during these cold days, so it's nice to have a little list of to-do's. Plus, it keeps me busy while I wait for Ford parts to show up in the mail. I am almost done wiring up the Model A, so there s also that project, too.
From little dot lights to this. Fun little job. Next up, make a bezel to mount the new speedo.
Gonna have to make it in two pieces. Working side done. Pretty side next.
Pretty side done. Now to attach them permanently. Gonna have to wait until Saturday or so. I should clamp both pieces to the rotary table and drill some equidistant holes. I'm thinking some #6 socket head machine screws sunk in to the ring from the top. Might be a little 90's-sh in style. I could spend a little more time and machine some holes to go through the back side. Maybe use some counter sink machine screws. Then really fool everyone and chuck the assembly in to the lathe to clean up the visible edge. At least from all angles it would look like it was one piece. We'll see what I'm inspired to do in the next few days.
Fox Offline
Very cool stuff. I love the lights idea.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The way these mount to the dash is oddball/horrible, I say! Yeah, I said it.
Ready to install!
The oddball/horrible stuff won't be visible. Looks good on the shiny side. thumbs_up
Okay. I think the side project stuff is done. I told myself this summer I do paint. No more excuses.
Worked on the intake a little more. I have a bit of sheet metal work to do to it. I still need to get the GPS speedo installed. Maybe this weekend!
Of course, pictures will follow.
Authorized Pest
Authorized Pest
Just noticed this Mark. You have over 800,000 views in your Project Journal. That's amazing and you'd done an even more amazing job writing it all up.
The Stovebolt Collective (and guests wink ) thank you.
~ Peggy M
1949 Chevrolet 3804
Thanks Peggy!
Okay. I only procrastinated forever. I thought installing it would be tough. Not so bad. I do have tons of stuff behind my dash with the AC and all. Nope. The toughest part was getting all the wires where they needed to go. Has to do my best contortionist act for that. I like it! Works cool too!!
I might have to make that other side prettier. It’s showing its age. Back to the cold air intake, I guess. There was something else I wanted to upgrade, but it slips my mind at the moment.
Daily driver until i get the AC replaced/fixed in the dually.
Need more light switch. This one ain’t to bright!
Mark, What is the lamp used in the speedo? Looks like a much higher light output range than in the gauges. Can you get matching bulbs to fit the gauges? The speedo light output color looks to be in the 6000K range.
~ Dan
1951 Chevy 3 window 3100
I believe the speedo is L.E.D., the gauges are incandescent.
Actually, the picture is very deceiving. The back lighting is actually pretty equal, although different color between the two groups. The headlight switch is failing. It wasn't the greatest when I first installed it. It'll probably be replaced soon.
Been a slow year. Didn't go to my usual October gig, doing push starts for vintage fuel dragsters. They called, but I just couldn't make it. Sometimes, I come up with an idea or two, then need to make a decision on how to implement it. That's where I am with my cold air intake. I have two designs, the rectangular flat filter, or a conical K&N filter. I made a housing for both, the flat filter being the more complicated version. I think I might've settled on the K&N version, half sinking the housing in the top of the inner fender on the passenger side. Tubing and hoses from the Tuned Port, with the other half of the tubing and hoses up in the fender area. Plenty of room so I'm not worried about wheel travel being an issue. Run that tubing toward the grill, then drop the intake portion to the bottom of the grill. Hopefully, all out of sight. Time to get back at it!
AD Addict & Tinkerer
Thanks for the update. It good to see your still at it!
Phil
Project Journals
Stovebolt Gallery Forum
Mark, sorry but I cann't recall what engine you are working with to provide the cold air intake. I scanned back through several pages of your journal but got tired of paging so just thought I would ask. A overall picture of the engine bay may give everyone a better idea of what you are working with.
1949/50 3600 Project
Follow in Project Journals
As you can see, I'm just grabbing warm/hot air out of that engine compartment.
Mark, thanks for the pictures. Engine compartment air temperature shouldn't be too bad if you have an electric fan that will be pulling in air regardless of engine and vehcile speed.
Sure, but colder air would be nicer.
I've been running it since 2012 without many issues. Just one of those project things I want to get to.
Directions number three. Where will this one take us??
I believe this might be a winner!!!
Are you planning on tubing connections for the inlet and outlet from the air filter housing?
Where did you come up with the hemispherical end caps, Mark? Those are kinda cool. Also, where will the air enter and leave the housing? Waiting patiently for more pics of the build. wink
Tube placement will wait on mounting location of the air cleaner box. I believe the intake will come in from the bottom, the tube to engine at the end of the service cap. I still have a ways to go on the box. I need to weld the caps and make bosses for the latches. The caps came from a place called Steel Supply LP in Texas.
This might be the only place.
The painting is planned out in my head. Has been for a few years. Just need to implement. Might have that extra time here, soon enough!
Moderated by  Phak1
