3 members (Jon G, Guitplayer, Wally / Montana), 123 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#829731 02/25/2012 11:13 PM
Hi - am rebuilding the mc and bought a rebuild kit for it. All the parts are the same on disassembly except for the spring. The spring I took out is about 2 turns longer than the replacement one. It still is quite firm.I am thinking I should reuse the old spring with new seals, etc. it's off a 37 gmc half ton. It's a delco. I'm pretty sure I bought the right rebuild kit off jim carter as the rest of the parts match exactly. Any advice? Also was going to paint it cast iron grey. Was it originally black?
Riding in the Passing Lane
I think you could use the old spring. The tension might be the same with a softer rate. Be sure the new check valve fits in the spring.
1972 Chevy c10 Cheyenne Super
Thanks. That's what I was thinking. I think it may have been rebuilt before as the piston is a bright blue color which I'm pretty sure was not the standard issue in 37.
