0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | just purchased a 1948 flt.dck. I believe it is a 3/4 ton. oh,and it is a canadian truck. can someone list the differences from 3/4 to a 1 TON. as all the codes on the American truck are different, I can,t use the posted codes. Thanks,Doug
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy z48 if you will post your serial number I will decipher it for you. | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thanx 3B the serial # is 8142306691 there are no letters in the serial # again thanx | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | First # 8 - 1948 Second # 1 - Chev Third # 4 - 3/4 or 1 ton , 1420 series 3/4 ton, 1430 series 1 Ton Forth # 2 - 125 1/4" wheel base Fifth # 3 - Cab type Remaining # 06691- vehicle # 6691 manufactured
Hope this helps | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | I will also add that if you want the full (but limited) production documents you can order them for about $40 for GM Canada at www.vintagevehicleservices.com/index.htmlYou will receive the paint and trim information , body number, where and when it was built,engine ID number etc. You will also receive the technical specification documents for the vehicle. It will likely be the USA version as they Canadian plant used the same documents to build. | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thanx for the replies. Helps me out. the 5th # is a 3 does this mean it was a cab and chassis ? it appears to have a factory deck on it with the sculptured side ,front ,and back panel.s. it also has the right stakes for all the way around the deck. Doug | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy z48, the parts book breaks down the part number a little differently 8 year, in your case 1948, but must confirm by body style 14 is the series code for a 3/4ton or one ton Chevrolet 23 is the model code, it confirms it as a 3/4 ton 125 1/4" wheelbase chassis with cab. the remainder is the vehicle number, hope that helps. | | |
