6 members (Youngin' Tut 59, Otto Skorzeny, J Lucas, 66flea, Buckeye998, asilverblazer), 129 guests, and 4 robots.
Topics128,185
Posts1,057,294
Members48,467
I have purchased fiberglass fenders for a 54 Chevy truck. My question is what type of primer should I use. I am planning on using Mar-hyde Ultimate 2K urethane primer and block sanding before the color coat. Does this sound okay?
Brimmer
http://1954chevytruckevconversion.blogspot.com/
It should be fine. But to be safe, get the tech sheet on the product from your paint supplier. it has all the technical info for that primer. it will tell you how to use it and what you can & cannot spray it over.
