8 members (Otto Skorzeny, Shaffer's1950, SlimSix, Hotrod Lincoln, TrknGMC, homer52, 2 invisible),
79
Mod | | | Forums66 Topics128,139 Posts1,056,451 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | What was stamped on the original taillight housings? Can anyone provide pictures? I am looking for a driver's side and passenger side for my '48 Chevy 1/2 ton p.u.
Thank you.
LUKE | | | | | Joined: Sep 2007 Posts: 15 New Guy | | New Guy Joined: Sep 2007 Posts: 15 | STOPRAY is stamped on top of my original '52 tail light housing.
Hope that helps. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | Thanks for the picture Denny. Is Guide stamped anywhere on the housing? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No, stopray stamped on the bracket also.
DG
| | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | Thanks--excellent information to have as I (and others) look for the real thing instead of the Chinese repops. Much appreciated! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I believe Guide was just on the lens if I remember right.
| | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | I believe this contains all the information a person would want about these taillights. Thank you for sharing it with us. | | |
