4 members (dunfire, John Dlugos, Gdads51, Greg_H), 69 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
My 1942 Chevy 1.5ton Fire Truck is currently titled and registered with the engine number. The VIN ID plate is missing. I would like to find the original VIN number. Is it stamped in any other places? Frame?
There was no VIN in terms of today's meaning.
There was a header-panel plate or a cowl plate (under the hood) with a Vehicle Serial Number (or Vehicle ID) and there was an engine serial number. Either one of the codes might have been used on the original title and/or registration.
Do you have an old title or registration?
http://chevy.oldcarmanualproject.com/chevyresto/4206.htm
http://chevy.oldcarmanualproject.com/shop/1942/42csm0003.htm
The title and registration that I have (going back to the early 60s) uses only the engine number. The plate on the cowl is missing. Only the 2 screws remain. I have no problem with the registration, I would like to get the correct VIN so I could get more information about the truck. For example, I only assume its a 1.5ton, I dont know for sure. I have heard that the VIN may have been stamped into the frame also, I dont know where to look for it.
I may be wrong but I think you will find a GM frame VIN right next to the hen's teeth.
You may be right but I have seen references to it in the stovebolt forum and in peoples photo bucket pictures.
Did they live in CA? A code was placed on the frame by the dealer and/or DMV in CA and maybe a few other places.
Also, GMC had IDs on the frame, I think up to May 1949.
Its always been in Washington State. Though it was built in Portland OR. It was a Fire Engine in Long Beach WA. They don't have any info either. The state DMV only goes back to the early 80s.
Serial numbers stamped on the frame didn't start until '55.
Bill Burmeister
Serial numbers were stamped on the left frame rail, just past the left front spring hanger on GMC trucks until the late 40's. Chevy didn't have a U.S built civilian truck rated above 1 1/2 ton until 1946.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Big Bolt Forum Co-moderator
Sammamish,
Of course my 48 doesn't have a VIN number since they didn't exist in 48. But the number on the plate is the original engine number. However, my engine has been replaced with a newer engine. That doesn't change my ID plate. It still is registered by the original engine number, not the newer one. If you were to get a reproduction ID plate, then punch the original number as it came from the factory. I don't know if anyone is making reproduction plates for 1942. Anyone have a picture of one? Are they different than the AD plates?
1948 Chevy 2-Ton
Yes, the ID plates were different in 1942 from the all the different styles of plates used in Advance-Design years.
1942-46 Chev truck ID plate
Greetings, I am having the same issue with my "41 Chev Howard cooper fire truck. There is an aluminum plate just under the passenger's side hood near the fire wall. It reads: 2557 6YSO1 3868
The registration shows A6399434. Anyone recognize either of these numbers?? If looking for the engine number, where would I start?
42 chev pumper
