| | | Forums66 Topics128,192 Posts1,057,227 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | My 1942 Chevy 1.5ton Fire Truck is currently titled and registered with the engine number. The VIN ID plate is missing. I would like to find the original VIN number. Is it stamped in any other places? Frame? | | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | The title and registration that I have (going back to the early 60s) uses only the engine number. The plate on the cowl is missing. Only the 2 screws remain. I have no problem with the registration, I would like to get the correct VIN so I could get more information about the truck. For example, I only assume its a 1.5ton, I dont know for sure. I have heard that the VIN may have been stamped into the frame also, I dont know where to look for it.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I may be wrong but I think you will find a GM frame VIN right next to the hen's teeth.
| | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | You may be right but I have seen references to it in the stovebolt forum and in peoples photo bucket pictures. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Did they live in CA? A code was placed on the frame by the dealer and/or DMV in CA and maybe a few other places.
Also, GMC had IDs on the frame, I think up to May 1949.
| | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | Its always been in Washington State. Though it was built in Portland OR. It was a Fire Engine in Long Beach WA. They don't have any info either. The state DMV only goes back to the early 80s. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Serial numbers stamped on the frame didn't start until '55.
Bill Burmeister | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Serial numbers were stamped on the left frame rail, just past the left front spring hanger on GMC trucks until the late 40's. Chevy didn't have a U.S built civilian truck rated above 1 1/2 ton until 1946. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Sammamish, Of course my 48 doesn't have a VIN number since they didn't exist in 48. But the number on the plate is the original engine number. However, my engine has been replaced with a newer engine. That doesn't change my ID plate. It still is registered by the original engine number, not the newer one. If you were to get a reproduction ID plate, then punch the original number as it came from the factory. I don't know if anyone is making reproduction plates for 1942. Anyone have a picture of one? Are they different than the AD plates? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, the ID plates were different in 1942 from the all the different styles of plates used in Advance-Design years. 1942-46 Chev truck ID plate | | | | | Joined: Nov 2006 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 18 | Greetings, I am having the same issue with my "41 Chev Howard cooper fire truck. There is an aluminum plate just under the passenger's side hood near the fire wall. It reads: 2557 6YSO1 3868 The registration shows A6399434. Anyone recognize either of these numbers?? If looking for the engine number, where would I start? Thanks 42 chev pumper | | |
