3 members (Guitplayer, Charles in CA, 1 invisible), 65 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#827384 02/18/2012 5:25 AM
Y
Y Offline
Okay, I've got 7 rochester carbs and I know thier model B BV BC? Only three have tags, is there a ID# on the carb that will identify it? I might assume that most kits available today will cover most if not all rochester "B" carbs? Another thing, are the kits from the flaps good enough or should I special order the kits. Any information will be appreciated. Thanks, Phil
Yakimabowtie #827398 02/18/2012 6:15 AM
The BC carb will be an automatic choke carb.
Most kits come with a 216 engine carb to intake gasket.If it fits a 235,you will need to get the appropriate gasket for carb to intake.I believe most kits cover all of them,I'm sure someone will chime in soon that knows for sure.
Tim
1951 3100 Chevrolet
bowtietim #827439 02/18/2012 2:25 PM
Carburetion specialist
"Only three have tags, is there a ID# on the carb that will identify it?"
Not on the carburetors produced prior to 1968. 1968 and newer carbs have a stamped identification number.
"I might assume that most kits available today will cover most if not all rochester "B" carbs?"
We have a total of 280 listings for Rochester "B", "BC", and "BV" carbs. There are a total of 81 DIFFERENT kits servicing these carbs.
Jon.
The Carburetor Shop
