2 members (Hanks custodian, TooMany2count), 102 guests, and 0 robots.
Topics128,134
Posts1,056,403
Members48,441
#82727 09/09/2007 4:39 AM
in my 1954 truck 1/2 ton put new gear cogs in the trans and this works have cable connecting both ends speedo and gear in truck and nothing works .
but works out of truck any clues please
#82728 09/10/2007 3:28 AM
What???? :hammering:
~Jim
#82729 09/13/2007 2:08 AM
Pull the speedo and twirl the speedo drive , watch to see the needle move , if thats ok , and the cable moves when you twirl it from each end then the square drive on the end of the speedo cable may not be engaging correctly.
Also possible is speedo drive gear on gearbox output shaft is slipping so no drive to cable.
