3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
I am considering a t5 swap.
Has anyone found a way to use convert a tailhousing with an electronic speedometer to mechanical?
Is the mounting hole for the electronic sender the same size as a mechanical drive? If it is, I think I can fab a sleeve to mount the mechanical gear.
No...the tailshaft housing is different and cannot be converted to a mechanical drive. However, there is a converter box that sells for $300+ that will do the job if you want to use your stock mechanical gauges with the electronic T5. Personally, I'd rather have a lower mileage transmission and be able to calibrate my speedo with the "cable-x" box. A rebuild on a worn-out high mileage T5, is going to be expensive and getting the stock speedos calibrated is hit and miss.
I'm currently running an 85 T5 in my 54 truck behind a 235. I have a bunch of T5 info in my webshots Shoebox album. Also some pics of the difference between the mechanical and electronic transmissions. Hope this helps you get started.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Yo Dave, been lookin' for two days for that info on the T5 but with my dial-up connection the graphics are just to much. You think you can post a link to the page??
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
