8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello,
I am looking for original factory mounting instructions for the 1954 Chevy panel truck , driver & passenger bomber style seats.
The drivers seat is mounted on four corners and the passenger is hinged on the front of the riser. I am looking for original factory mounting and placement instructions/drawings.
I believe the passeger seat was a option. Thanks
jorb | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jorb,
Interesting question. Yes, the seat was a factory option (RPO-263B), so the holes would have been drilled at the factory.
Let's hope that someone will post the location of the holes in their panel (if it has the passenger seat option). If no one posts information, I'd just place the seat where I like it and they drill the mounting-holes in the floor?
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | My truck had holes for the driver's seat, so when I found one, I just bolted it on. I can take a picture of the passenger area, there are holes there too. I mounted another driver's seat there, using a yoke for a hinge. I'll try and take some pics if you want today. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I don't see the holes for the passenger side seat in this picture | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | My truck had holes for the driver's seat, so when I found one, I just bolted it on. I can take a picture of the passenger area, there are holes there too. I mounted another driver's seat there, using a yoke for a hinge. I'll try and take some pics if you want today. I would appreciate any photos/measurements you have. Thank You jorb | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Okay, I'll look for the camera! | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Tim The 47-54 assembly manual shows seat info on the pick-up truck but not much on panel truck. There had to be instruction on the drivers & auxiliary seat placement for the factory worker. Maybe they found the burn barrel. Then again after the first 20 panel trucks they could have eyed them up and drilled the holes. I think the both panel truck seats where all the same from 1947-1955 1st series and maybe beyond that. Also I think the same years used the same riser for the panel truck. Link: below shows seats for,1955 56 57 58 59 CHEVROLET GMC PANEL. panel seats The seats look like the 47-55 1st seats.seller could be wrong. Thanks jorb
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | I don't see the holes for the passenger side seat in this pictureWhat year is that riser. Thanks jorb | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I don't see the holes for the passenger side seat in this pictureWhat year is that riser. Thanks jorb 1947/1955 Chevrolet/GMC Panel | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | GMONIZ
Are you saying 1947 thru 1955 Chevrolet/GMC Panel.
jorb
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Yes this is the seat riser out of a 1947/1955 GMC or CHEVROLET PANEL. I know that the passenger seat was an option, but I can not find any installation instructions showing the two seats. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Here are pics. Here is a pic with the tape next to the driver's seat. You might note that the raised areas stop where the seats mount. http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2193.jpgHere is the passenger side. You can just make out the hole 5/8" from the edge, and at about 14 1/2". I THINK these are the factory holes, as they are much "nicer" than the others on my truck, and don't SEEM to be drilled at home. http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2195.jpgAnd here is how I mounted the passenger (which is another driver's) seat. http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2198.jpghttp://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2196.jpgAs you can see, my truck is quite grubby apparently. Darn mud. I cut the bottom of the seat bracket off, and used a yoke as a hinge. I still need to get a shorter yoke, as the seat sits too-high. I also need to turn the rear blocks round, I never bothered to, as I knew I'd be making shorter ones anyway. Now, I used two driver's seats, that came out of one other truck! In fact, I even bought the seats at different times, from different owners of the same truck! My panel didn't come with any seats. The passenger seat mounting holes should be located in the same way as the drivers, (I think) inboard passenger holes would be located where the raised areas are interrupted. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Mr. Lang
Your passenger seat mounting looks better than the factory set-up and with a little tweaking could be a lot more adjustable.
I am trying to keep my truck as original as possible. I have seen some photos of what I believe was original passenger seat mounting and there is a three point bracket. It is fastened with Two bolts into the face of the seat riser and one into the top. That is probably the 5/8" hole from the edge you are talking about. Is there any holes on the riser face just down from that 5/8 hole?
Thank You for the pictures they gave me some ideas of where the seats are suppose to be mounted.
Correction: The two mounting brackets are fastened with two bolts each, 1 into face of riser and 1 into top edge of riser. The brackets are mounted on two points, not three. This applies to 1947-55 1st series Panel Trucks auxiliary seat.
jorb
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | My seat riser, only has one hole where each "bracket" would go. Perhaps my holes aren't really factory seat attachment at all? It's hard to say, as when the conversion was done on my panel, lots of changes were made. I have a '54 heater for instance!
The passenger seat in my bus, being another driver's seat, slides back and forth, as well as flipping forward/folding. It works pretty good, although I have so few passengers I don't know why I even bothered putting it in! | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | My 53 panel had no mounting holes for the passenger seat. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | CL means centre line. The centre of the truck, so the seat is off set 4.6 inches from the centre. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Oh, and that's a great link, thanks. I've seen a poor scan of that before, but this one is top notch! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If the placement of the two seats is supposed to be symmetrical, Place the passenger seat in the "mirror location" on the other side of the mid-line. Mark the holes and drill?
Do you have the passenger seat base?
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Now those are great pictures! | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | 1953 panel Your hinge brackets are different then these. 1954 panel seats I believe these are original from 1954 panel jorb
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Tim The truck came with two after market seats installed, they where mounted way to high. I am trying to return factory seating. I have a early 50's original drivers side seat with base that came with truck.(rough shape) I do not have a a passenger side seat,but I am waiting for a seller to send me pictures of both seats that are in great shape with all the mounting hardware and bases. Trying to verify if what he has is correct.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Thanks for CL definition. This is what I am looking for: seat instruction for 1955 sedan delivery But for the 1954 Chevy panel truck seat. jorb
| | | | | Joined: May 2010 Posts: 43 Shop Shark | | Shop Shark Joined: May 2010 Posts: 43 | Hey, just FYI those seats and brackets in the photos at the bottom of page 2,(shop shark/ontario) are 41-47, not 48-53.... Jorb's photos of the 54 are the correct ones. Steve
Last edited by tclederman; 02/17/2012 8:07 PM. Reason: please buy/sell via email and/or private messages
