1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#826413 02/15/2012 2:32 PM
need a little help. i am re-wiring my 50 3600 to 12v and i just wonder if i could still use the old 6v headlight switch. it is in good condition and i hate to just trash it. also the dimmer switch. whats the word fellas?
really like the stovebolt site. not the sharpest file in the drawer when it comes to computors. better at rebuilding parts. hope im in thanks guys rodC66
rodC66 #826415 02/15/2012 2:48 PM
Should be fine.
Yes. No problem.
Kurt
Should be fine, Going from 6 to 12 volts, your switch can actully handle twice the load.
Ohms law: VoltsxAmps=Watts; or E x I= P
ex. 6 voltsx20 amps= 120 watts; 12 voltsx20 amps=240 watts
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Only one issue that I know about. The thermal fuse on the switch can also carry twice the load as well.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #826578 02/15/2012 10:31 PM
If he is using the original gauge wires, the thermal fuse will protect the wires OK. If he is using smaller gauge wire, then maybe a problem.
Kurt
thanks for the come back guys. yes i do intend to use the same guage wires. i thought the switch would work,but i thought i would get some other opinions.
