2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Saw this on another board. Looks like a good idea and an easy swap.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Clever idea although a question has arose on his grounding wire. And, why if you go to this extent wouldn't you take the time to clean up the light? Too much corrosion for me.
Drew
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Have you addressed the 6v/12v issue yet? Oops, never mind, I see your a long way from a stock '50, 3600. DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | This is a neat idea. Unfortunately, I run 6 volt.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'll bet he has a lot of light in that cab. He can probably read the small print on a Chinese map. lol I swapped to LED lights on my front park lights and brake/tail lights. Much improved! I also added LEDs under the dash and door poppers. The effect is awesome.
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And if you’re not really interested in ruining a $50+s&h AD interior light, there is always this: http://www.harborfreight.com/27-led-portable-worklight-flashlight-67227.html These are powered by three 1.5v AAA batteries so if you really want to stuff it into your $50+s&h housing, no problem, just add a small dropping resistor in series to drop a couple of volts, same thing if you want to drop it from 12v: http://www.pbase.com/dennygraham/image/141528423 I prefer to use the, quite adequate magnet on the back and just stick it where ever I need light in the cab. And if you’re stuck under the hood out in the boonies, it even has a nice hook folded into the back that pivots every way but loose. And it’s only $3.99 at HF right now. http://www.pbase.com/dennygraham/image/141528424 http://www.pbase.com/dennygraham/image/141528425 Denny Graham Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Dang Denny, you should be selling used cars! lol
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Aw, C'Mon James, I'm just lookin' for a cheap way out and tryin' to preserve those vintage parts. I made a set of bed roll lights from a couple of those buck and a half nine LED lights a few years ago. http://www.harborfreight.com/35-inch-9-led-mini-flashlight-65020.html These are some of the few items that are worth the money at HF. DG
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Denny, don't tease us. You know you've gotta post some pictures on how you did this!!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | But, but, but, Robert C., that's the point, I didn't do anything. Cept buy a $3.99 LED flashlight from HF. Point was if you want more interior light you don't have to butcher up your original dome light, they are quite expensive you know. If you want to light up your interior this LED flashlight with it's magnet and or hook is just the ticket. When I'm out at night and need to light up the inside I just reach up behind me where the dome light is and push the button and its portable if need be and you can hide it in the glove box when the judge comes around.
DG
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Now Denny, you're not using that little light to text while driving are ya?
~Jim
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I like your backup light solution.
You stop in the middle of the street, get out of the truck, go back to pull out the flashlights in the bed curls, turn them on, put them back in, get back into the truck, and proceed to back into the driveway or parking spot.
Interesting
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I don't mean to hijack this thread, but has anyone ordered stuff from Hong Kong? That is where the light panel is located according to the Ebay listing. I have recieved a few things from Canada, but I have always been a bit leery of ordering from other countries. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Not me; I would have to be out of options to do that.
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jimmie D, come on mon, my fingers are getting sore from typing. You don’t have to wait for it to come from Hong Kong, they’re already here and for only $3.99. That’s what I’ve been trying to say, just pull the light board out of the HF unit that I've posted all the pictures of. Only change you have to make is go to a little higher value resistor and you got it made. The HF board has a 4x6 light pattern which will fill the lens better than that 3x8 board anyway: http://www.pbase.com/dennygraham/image/141551944/large If’n you had a mind to do some experimenting these boards could even be adapted to fit in tail light housing by wiring different resistors in series for the tail and stop circuits. In fact, now that you got me to tear one apart I might just do some spear minting with this one and a hand full of resistors to see how that would work. Dennis, no need to leave your easy chair for the bed roll “flashlights”, here they are hooked into the 6v stop light circuit, or they could be connected as turn signals if you wanted that of just left as additional tail lights: http://www.pbase.com/dennygraham/image/122737326/large http://www.pbase.com/dennygraham/image/122737355/original Denny Graham Sandwich, IL
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I've bought stuff from China on ebay before. You just have to look at the feed back and stuff, just like with sellers in NorthAmerica. In fact, with the help of a friend in Beijing, I bought stuff from Taobao, which is like China's ebay. I was buying stuff for my bike, which is Chinese, and awesome. http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2169.jpgTo add truck content to this post, I have spear mint gum in my glove box, also gloves which smell oddly like mint... | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I have trouble paying $100.00 for a set of bed roll lights, how did you make yours?? red49. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Same here Red, and that’s why I’m playing around with these LED flashlights as light donors. LED’s are as cheap as dirt now days as are LED arrays on circuit boards. What you pay for is the adaptation of the boards to fit in the light housings or in this case a plug for the AD bed roll. Again, this is just a couple of the heads off of those cheap little LED flashlights that you see on the counter displays all over. The plug is made from a PVC plumbing reducer turned for a snug fit in the roll, and the red lens is cut out of a reflector using a hole saw. http://www.pbase.com/dennygraham/image/122737145/original scroll [next] for more pictures. All that’s needed is an inexpensive film resistor (Radio Shack) to drop a couple of volts in the 6v system and of course a higher value resistance for the 12v systems. There are tons of web pages devoted to the use of LED, here’s one for example: http://www.otherpower.com/otherpower_lighting_leds.html If you don’t want to pay big bucks for LED lighting, then you need to do a little experimenting and innovating. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I thought I would add some information to this thread. While on Ebay the other day I ran across a seller (digi-accessary) and purchased a 3 x 4 white LED dome light for $5.99. It comes with three different adapters to fit various applications. I had it in my mind that the bulb in the 52 was smaller than it was, so I wound up soldering the leads to a 1156 bulb base. It works great!! These LED's are 12 volt so no fooling around with resistors. I think he also sells the array in 6 volt. It was a quick and easy upgrade. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well always glad to hear other options Jimmie, but why don't ya post a link to his store for us, I personally can't find my way around ebay. But.........is this the guy? Looks like he's got a ton of lights, I thought I saw a number like 23,739 kinda hard to find the one you bought. http://stores.ebay.com/digi-accessary DG
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Hi Denny, yes that is the link to his store. I should have posted the link, but I didn't know how much interest there would be in the upgrade. I couldn't find an item number for the item I bought, but if you use the link and type in dome light in the search box it takes you right to the one I purchased. | | |
