8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82605 09/06/2007 6:33 PM | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | What is the easiest way to release the spring tension to replace a rear leaf spring mounting shackle? | | |
#82606 09/06/2007 6:52 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Support the truck by the frame, then use the floor jack under the axle to hold the spring tension. Slowly lower the jack after taking the shacles loose. That's how I did it.
Bill Burmeister | | |
#82607 09/06/2007 9:35 PM | Joined: Jun 2007 Posts: 21 Apprentice | | Apprentice Joined: Jun 2007 Posts: 21 | | | |
