5 members (Millenimech, Stewart2, Gib70, Hotrod Lincoln, 1 invisible), 135 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#825488 02/12/2012 5:52 PM
Can anyone tell me how much the empty cabs weigh on my 52 9430 one ton pick up? I am thinking of using a chain fall to lift it off and want to make sure it's not to heavy for my steel A frame shop trusses to hold. It would be nice to leave it in the air to take up less floor space.
I would guess it would be around 500-600 lbs?
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
If you have an engine hoist, this is the easiest way to do it.
Bruce
My Trucks
Stuff I Collect
Thanks Bruce, I don't have an engine hoist....yet! Good idea though, if it isn't to heavy I want to hoist it hi over head to keep it out of the way.
I don't think it's more than 300 w/o doors. I first lifted it off with 4 guys. Then just 2 of us put it back on. It was very manageable.
https://picasaweb.google.com/113636046886857960240/TruckVideo#5623035907526892098
Oh really, I haven't tried to lift mine yet, just assumed I might blow a nut without some mechanical assistance. I guess it just looks heavy.
should be no problem to hang from above.
Thanks guys. thumbs_up
I wiggled mine off my parts 2ton by myself. A little wiggling and waggling and some blocking and it slid right off. Couldn't do it once its painted, but before bodywork, wasn't too bad. BTW, that had the doors off and the cab stripped of most everything inside.
Gravity was my friend on that deal.
Moderated by  Dusty53
