1 members (baldeagle), 107 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#825112 02/11/2012 4:43 PM
that would be the parking light on your pre-sealed beam setup
Thanks Bill
Could these be converted to be used as turn signals?
I wouldn't expect other drivers nowadays to understand a flashing headlight bucket meant you were turning rather than about to burst into flames grin seems like it wouldn't be very visible in daylight and not at all at night when the headlights were on
when I had a 37 Ford with that style lights I converted to a more modern setup with halogen bulbs in the headlight buckets and separate lights for turn signals mounted on the bumper irons like fog lights .... I believe Chevs of the 40's would have some conversion options for upgrading the headlights to be more useful
You can buy modern seal beams with the top section blocked off to create a signal light " built-in ". You may be able to duplicate this setup by adding a bright metal " partition " to separate from the headlight so it wouldn't get lost in the glow ?
You can convert from parking to parking / signal using a 2 post socket & bulb.
1940 Chevy KC 1/2-Ton
Forget the idea of using the internal park lamps as turn signals..they won't be seen, as mentioned. I also don't like the signals in the composite headlights, because if the headlights are ON, you can't see them! Shame on Mercedes for starting that crap.
I mentioned my add on ideas in another post.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
