0 members (),
136
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, yeah, I know, the door came open when they ran into a tree, or the door was open when they backed it out of the barn or it got caught on a fence post. This seems to be a pretty common ailment for the AD. This is mine new patient, a ‘54, 3604, but the door doesn’t seem to be damaged at all. When its closed it fit’s the opening fine and latches as it should: http://www.pbase.com/dennygraham/image/129182914/large I say common because I’ve now seen several and just this week I was talking with a friend who has the same damage on his ‘53 GMC. It seems to me that for the door to do this much damage the hinges or A-pillar or door itself would have to suffer some damage also but in actuality the doors seem to escape un-damaged. Andy ideas about how they accomplish this feat? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | Mine was the same way.. Door was not damged.. I'm still wanting to learn the story on how it happened.
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | easy, done it myself back in the day, backing up with door part open and it hit a hedge while I was looking to the other side .... that sheet metal panel at the cowl has little backing to resist the door edge and the hinges are pretty tough if the pillar is sound - happens pretty easy at slow speeds, takes faster with much more force to tweak the front flange of the door, but I've seen that happen too
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy that 'A' pillar, hinges and door frame must have an orfull lot of comeback Bill. I can give a real good tug on the door and the front edge doesn't seem to come close to the cowel. Ya haven't made a believer out of me, but I'll take your word for it for now. Don't think I want to try it out on the other side to see if it works though.
Tks for the comments,
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 'real good tug' doesn't exert much force, that's why body shops use hydraulics like Porta-Powers to rearrange things, kinda like 100hp pushing a ton of truck would do .... if you 'fling' the door open you might see where the flex and twist will happen in the pillar and door, the pillar doesn't have to get permanently deformed to twist a long way
Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The door catch will most likely have to fail for the door edge to contact the cowl. Those are easily replaced. I suspect sometime in the past the door catch failed and was replaced.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | My "theory" the driver would be so PO'd after doing the damage, get out and slam the door shut, sort of un-doing the damage? I know from working in a bodyshop that they had special tools for "springing" the door/hinges back into alignment. I used a socket, placed inside the hinge, then force the door closed. This all happened back in the day when they were made in the USA! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I also found evidence of this type of damage on mine,but put it down to a front left fender impact,the fender below the headlamp was badly damaged and I assumed the cowl was a knock on effect,but now you've got me thinking..... Mine was repaired with lead,so I assume it happened quite a while ago. AFAIK the door is original and fits pretty well but shows no damage related to hyperextension of the hinges.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
