3 members (Peggy M, mick53, kades51), 51 guests, and 9 robots.
Topics128,012
Posts1,055,313
Members48,419
#82426 09/03/2007 1:48 PM
Have a dist from a 82 GMC with the electronic metering rods in the carb. I have heard that these are hard to convert to the older style. It has 2 wiring harnesses coming out of it. Can this be done and what about firewall clearance in a 64?
#82427 09/03/2007 3:02 PM
Riding in the Passing Lane
It can be converted but these things are laying around everywhere it would be just as well to find one without electronic engine controls. Ther is good firewall clearance on a 64. The 55-59 models give a clearance problem.
1972 Chevy c10 Cheyenne Super
#82428 09/03/2007 3:21 PM
Thanks wrenchbender, i was going thru my old tool shed at my mom and dads yesterday and run across it. Had it on hand so thought i might try it. I will keep looking.
#82429 09/03/2007 7:16 PM
Is this a V-8 you're working with? The 305 4-barrel engines with Electronic Spark Control used a 5-pin module with a different spacing on the alignment pins to the housing, so it would take a major rework of the housing, plus a different wiring harness and pickup coil to make it work.
It's simpler to get an old-style HEI distributor with a 4-wire module and the right pickup coil for a conversion job.
#82430 09/03/2007 11:18 PM
Yes, its a 327. I guess i will keep looking for a older model. The pin spacing is the issue.
