3 members (Gdads51, Ol'55, Otto Skorzeny), 101 guests, and 2 robots.
Topics128,049
Posts1,055,649
#823906 02/07/2012 9:24 PM
che
Offline
any pointers on how to get the parking brakes to work on a 50 1/2 ton. only one wheel is currently hooked up to the emergency brake but even when i push the emergency brake pedal with all my might, it does nothing to hold the truck even on a slight incline. i shortened the cable going to the brakes so it would do a better job but still nothing. i plan to install a cable for the second rear wheel soon if i can find the internal drum parts. i couldn't find much in the forum on this issue. have others encountered this problem and found a way to solve it. thank you.
Che
1950 Chevy 3100
che #824048 02/08/2012 5:44 AM
3B Offline
Hy che, are your brakes adjusted up properly? Have you pulled the drum(s) to check that the cable and levers are in position and connected as they should be?
