1 members (Hotrod Lincoln),
118
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | Looking for ideas for adding turn signals on my 37 1/2ton. Don't want them to take away from the original look of the truck. Anyone have any thoughts or products that work well?
Thanks, Charlie | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Have a look on ebay, at some of the vintage signal lamps that come up for sale. I like the look of some of the old ones that are a light-up arrows, with little visors on them. They do seem to be pricey though, as the rad rodder types like them too.
You can get re-pop signal stat type switches, but I don't care for them, as they don't seem to hold up as well as the old ones, but maybe I had a bad one. I had the seven wire model. | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I have a 38 GMC which is about the same . I used Hottronices self canceling turn signal set up works off a spring loaded double throw toggle switch or 2 push buttons, I like it and it works good . For front turn lights I found some Harley Davidson bullet turn signal lights that look similar to our head light buckets then fabricated a bracket to mount them to the front bumper. They not only look good, they also look like they belong on the truck
1938 Gmc 1/2 ton
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | I was looking at the headlights with the built in turn signals......anyone use these before? Chevs of the 40's Charlie
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Your original post said you didn't want to take away from the original look. If you decide to go with halogens be aware of the current requirements of halogen lights. I'm not saying you can't go that route just be aware that it's likely not a plug-n-play situation.
| | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | I used the xenon w/ directionals (check spelling on this)but my situation was completely different. I did not go the stock route my wiring system is a modern (Painless) system. They do fit in the 37 buckets but have a flat lense. I also run a separate relay. check out the photo in my bucket. If you are going as stock as possible find 7" seal beams, 6 or 12 volt. and go with added directional lights. I used motor cycle bullet lights for additional brake lights Just my 2 cents Al
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Tiny, those lights look great on Sweetie, like Buck Rodgers! | | | | | Joined: Sep 2010 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 90 | Al.....what kit did you use from painless.....been thinking about possible going to a new setup....12volt.
Charlie | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Tiny, those lights look great on Sweetie, like Buck Rodgers! Up, up and awayyyyyyy.
| | | | | Joined: Mar 2000 Posts: 116 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 116 | I fitted my 37 1/2 with turn signals by buying a relatively inexpensive signal kit (that bolts to the steering column). I believe it was a 7-wire kit. It required a flasher. I already had a nice set of original fog lamps on the front. The kit allowed me to wire directly into these and into my stock taillights. It was a pretty simple add on and they work very well. I should mention that when I restored the truck, there was no wiring left, so I rewired for 12V.
Good luck.
Jim | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Those fender mounted lights Tiny mentioned are the closest to original looking....or you could find some '40 park lights and convert them to 1157 bulbs, like I did. Some were on Ebay for $60 recently, or available repro also...Good luck.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
