0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#820358 01/28/2012 1:23 AM
OK i've decided to make my 2wd into a 4 wd . I know suburbans work , but i'm pretty sure it's just for the short bed , any ideas on one for 55 2nd series long bed , any leads or info on a napco setup , any info would be greatly appreciated , thanks
Sorry I couldn't reply earlier. The computer I was using wouldn't keep me logged in to reply.
Here are links to the two Napco forums I know of:
http://napcopowrpak.groupee.net/groupee/forums?s=5271003771
http://napco4x4.org/forum/
Every once in a while I see Napco stuff on Craigslist, but not very often in my area.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Contact Omar Lugo at Lugo Parts and Restoration he is the most knowledgable NAPCO expert out there. You will not be dissapointed.
http://www.lugoparts.com/
A Family of Task Force Trucks
1957 GMC 150 NAPCO
1957 Chevy 1/2-Ton Short Bed
1957 GMC NAPCO -2
Stories in the Gallery
More truck pix
fritter #823494 02/06/2012 2:59 PM
I changed my 1957 Chevy long bed into a NAPCO 4wd. Off the top of my head: some things to consider:
- 1/2 ton NAPCO drive trains are much easier than 3/4 ton to find
- Get the best drive train you can afford, hopefully it will only
requiring bolting in. I bought a lower cost set and had to
rebuild both axles, hubs and transfer case. The upside is that
I learned a lot.
- Get both front and rear axles, the need to be the same ratio. I
changed mine to 3.38 for highway cruising
- Depending on the year, some parts like brake pads and wheel
cylinders seem hard to find and you may need to get a machine
shop to rebuild them (I did)
- Make sure all the pieces are they, e.g., shift lever, lift
blocks, and linkages.
- If your truck is a long bed and the NAPCO drive train is from
a short bed, you will need to locate or get a longer rear
driveshaft made.
Overall, if the drive train is in good shape, it isn't a difficult install. It took my son and I two days, but we took our time. If you like 4WD trucks, the end result in my opinion is really great looking.
