4 members (lumbersawyer, Hush, 2 invisible),
64
Mod | | | Forums66 Topics128,026 Posts1,055,407 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | The fuel pump on my '48 3100 drains back when sitting, as evidenced by the level of gas in the glass dome getting significantly lower than when it's running. Is this normal? I don't have any problem starting the truck, even after it has sat for two to three weeks. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You may have a bit of crud holding the valve open just a bit. It shouldn't drain back. If it were me I'd buy a spare pump to keep on hand in case that one gives it up. If you haven't already done so it wouldn't hurt to put a filter between the tank and fuel pump.
