1 members (RLB),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | I pulled and disassembled my '48 235 motor. My local machine shop is charging me $1836 for engine kit (all gaskets, new pistons, new cam, new lifters, new bearings, new timing gears, new oil pump) hone/bore cylinders, machine my rods to accept insert bearings, rebuild my head with hardened seats, assemble the bottom end. It seems very reasonable to me, he has rebuilt a number of these 216/235 babbit motors, and answered every question I had. I am curious what others have spent? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Sounds reasonable to me too.
| | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | that sounds right. people typically are selling rebuilt ones anywhere from 2k-2500 bucks. but at least this way, you will know what has been done to your engine and not just what someone says. -DVZ | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That sounds to good to be true and is about 1/2 the cost that most rebuilds run. A complete short block rebuild usually runs about $2,000 to $2,500 and a complete head rebuild $400 to $500 in most parts of the country.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That sounds about right for a good price on the parts alone! | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | extremely reasonable, assuming the work gets done correctly. I had "reasonably" priced work done only to have to get it done again. fortunately I found THE shop all the other shops farm their work out to, it is very close to my house rather than a hour and a half drive away. unfortunately it was after I had spent a considerable sum already... but now I know.
| | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | That's almost exactly what I was quoted yesterday for a full rebuild on my 1956 235 motor... | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | how do they deal with the babbit bearings? Do they put shells in? or do they pour new ones?====dave | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | looks like he is having the rods machined to accept insert bearings.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2011 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 117 | Sounds a bit low to me. I just finished a 1959 235 rebuild and spent $2300 on the long block machining and parts. I did the assembly myself on everything but the head. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Sounds a bit low to me. I just finished a 1959 235 rebuild and spent $2300 on the long block machining and parts. I did the assembly myself on everything but the head. That's right at what my 270 ran in '08 for the same assembly 'package'.
| | | | | Joined: Sep 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 49 | Has anyone used a 235 Reman engine? I see them on EBay often for around $1500 for a long block. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I am in Portland OR. 216 (1953 engine by the numbers) - I paid out the door 3500. I had a complete rebuild, The mains were insert and they bored the rods out for inserts. Redid the heads hardened seats etc, machined the manifolds to each other, balanced the flywheel and clutch assembly bored etc. | | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | I spent $2000 and did all work myself except head machining and balancing of flywheel and crankshaft.
1951 chevy 3100 short bed frame off resto.
| | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | yeah --I see--they are using inserts. I could not imagine getting the bearings repoured and scraped by hand for that low price. Probably very few around that can repour and scrape. Good to know about the other option though! I put a 235 rebuilt motor in mine but having the original engine is even better I think as there are no modifications down the line to deal with. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | These 2 sites were refereed to me. Both have Babbitt Service & sell kits. Pauls Rod & Bearing http://parkville.info/pauls/ Kanter Chevrolet Truck Engine Kits http://www.kanter.com/p18-chn.htmlGood luck. Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Not being too bright on engines, I've had several rebuilt by Pro Machine here in Rapid City. On my '54 1 ton stake, he charged me $1300 for a complete rebuild of the 261. Every engine he has done for me has been great. I'm hoping to fire up the 261 this summer.
Bruce | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 |
BobS46
| | | | | Joined: Sep 2011 Posts: 116 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 116 | I just got my 248 back from the shop and mine was in the higher end of this discussion, hard to find parts for this engine and when you can find them, you pay. Thought we had stuff lined up before teardown then would get the "oh those have been discontinued" line. Did get it done though and it's back in the truck awaiating first restart. One funny thing that did show up was the rod bearings were 30 over and came in a celophane package that was obviosly old, date stamped on bearing was 1960 so they had been setting on someones shelf for over 50 years. Anyone wanting to rebuild a 248 might not want to wait too long, parts are getting scarce. 1955 Second Series GMC"Done - A 50 Year Journey"Follow in the DITY-- No one said it was going to be easy
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I just got my 248 back from the shop and mine was in the higher end of this discussion, hard to find parts for this engine and when you can find them, you pay. . Anyone wanting to rebuild a 248 might not want to wait too long, parts are getting scarce. that's what my machinist said when he did my 270 in 08... I figured I'd let the next guy deal with the SBC switch though as I prefer original and rare to the alternative
