2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | Anyone ever had a water pump rebuilt? I have a 235 with a short shaft. Quotes from 3 places run $70 - $90 (Flying Dutchman, Water Pump Man, Arthur Gould) and would include new bearings, seals, gaskets, clean and paint. Thanks. Newbie 1950 Chevy 3100 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd buy the $30 one from Rock auto, Press the pulley mount to where I need it and cut off the excess shaft. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've got a noisy one in my ‘50 right now, not leaking yet but it sounds like I got a Jimmy 4.71 blower under the hood. I bought it new from Rock Auto 7 years and 10,000 miles ago for a little over $75. So I went to Rock Auto's catalog to order a new one, no listing any more! Looked to JC, Chev's of the 40's and a couple others and they are up around $120 now for a new pump. Don’t want to put a used pump on cuz the few that I saw, even though they blasted them and painted them a pretty color, the snouts were pretty badly putted from rust under the paint. Back when I was a teen working in the Chevy parts department we stocked the bearing/seal assembles for them. In fact I replace a couple in my own cars. It’s a simple matter of pressing them out and pressing the assembly back in. Problem now is only the rebuilder have access to the bearing assemblies now. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
NAPA lists a remanufactured 1950 water pump for about $70 plus shipping (it is interesting that they now charge shipping for items not in the local warehouse).
| | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | At my Napa it's $92 and they said the shipping charge is due to the fact that it's not coming from their warehouse but rather directly from the dealer.
I would rather stick with parts I know work and fit my engine. Already made the mistake of ordering one from Eckler's prior to knowing there were different shaft lengths so I've got a cool door stop/paper weight.
I have no interest in cutting excess shaft lengths, etc. I'm a newbie and overwhelmed to begin with! Newbie 1950 Chevy 3100 | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | If you can get someone to rebuild it I would go that route. You would need the right tools to press the flange and cut the shaft on a new (rebuilt) one. If you are able to get it rebuilt please let us know and for how much. The bearings on my short shaft pump went out but I couldn't find a local shop that would rebuild it...I fortunately found another one on ebay. There's always the option of getting an adapter plate to fit a 216 pump. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=655391http://www.ebay.com/itm/1955-1962-C...0456073982?item=140456073982&vxp=mtr
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | At my Napa it's $92 and they said the shipping charge is due to the fact that it's not coming from their warehouse but rather directly from the dealer.
I have no interest in cutting excess shaft lengths, etc. I'm a newbie and overwhelmed to begin with! Short shaft pumps are not manufactured. They are cut off standard pumps. If you order one from NAPA it will be another standard pump. If you already have one it is not a "doorstop". It is what you need to get your truck on the road again. | | |
