3 members (BC59, 2-Ton, Forty9),
104
Mod | | | Forums66 Topics128,128 Posts1,056,685 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | was wondering what the diameter of the bolt pattern on bigbolts was, just thinking about hubcaps again. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy PapaJ, the five on the front ten on the rear bolt circle is 7 1/4", if you would tell us the year and model of the truck we can verify that that is the size you're asking about. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | 53/6100, what i'm looking at is the outside diameter from outside lugnut to outside lugnut. Looking to pop on hubcap like on big rig rear axle hub cap, if I can find one to fit.
