9 members (Gdads51, 68ironhead, Jon G, Wally / Montana, 3B, Bill Hanlon, Gray_Ghost, Rusted Nut, Shade Baby), 172 guests, and 1 robot.
Topics128,104
Posts1,056,197
Members48,436
Looking for suggestions on how to remove the crank turner/connector on my 1946 216 engine so I can remove the pulley.
Thank you.
Harold
Harold
You cant remove the crank until you remove the pulley. You will need the proper puller.
I think they call it a harmonic balancer puller. It uses two bolts that thread into the pulley and the puller shaft rests against the center.
1951 1 Ton Completed
mo Offline
you can use a steering wheel puller. done it thousands of times. make sure you have the right bolts to bolt into the harmonic balancer/pulley, tighten the bolts all the way and make sure their even then tighten center till it comes off.
MO's 1951 chevy 3100 resto mod project
Thanks for the info. If anyone needs detailed instructions & photo's let me know.
Harold
Harold
Make sure the puller screw gets all the way through the center of the balancer and pushes against the crankshaft snout. Sometimes it's necessary to slip a small-diameter deep socket into the center of the balancer so the puller jackscrew doesn't push against the hand crank ears on the balancer instead of the crankshaft. I've seen balancers and pullers broken by people who weren't paying attention to what they were doing.
