| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Looking for suggestions on how to remove the crank turner/connector on my 1946 216 engine so I can remove the pulley. Thank you. Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | You cant remove the crank until you remove the pulley. You will need the proper puller. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think they call it a harmonic balancer puller. It uses two bolts that thread into the pulley and the puller shaft rests against the center. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | you can use a steering wheel puller. done it thousands of times. make sure you have the right bolts to bolt into the harmonic balancer/pulley, tighten the bolts all the way and make sure their even then tighten center till it comes off.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks for the info. If anyone needs detailed instructions & photo's let me know. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2004 Posts: 29,801 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,801 | Make sure the puller screw gets all the way through the center of the balancer and pushes against the crankshaft snout. Sometimes it's necessary to slip a small-diameter deep socket into the center of the balancer so the puller jackscrew doesn't push against the hand crank ears on the balancer instead of the crankshaft. I've seen balancers and pullers broken by people who weren't paying attention to what they were doing. Jerry
