| | | Forums66 Topics128,051 Posts1,055,735 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | I use both and a lot of the painting I do is on fiberglass and aluminum. What is your opinion on the clearcoat? Other than the time restrictions with catalyzed clearcoat, I don't see much difference?
59 Apache Long Fleetside 4x4 Big Back Window 53 Chevy 3/4 ton Longbox 63 Chevy Shortbox 64 Chevy Longbox 4x4 71 AM General Deuce and a half M109A3 84 Chevy Blazer M1009 Diesel 83 GMC 3/4 ton 4x4
| | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | I will add that the painting i do is in and gone so I don't get to see it months or years later to see how it is holding up. I did a fender repair on a Sterling Acterra truck 2 weeks ago and had my paint distributor come out and prophet II the truck to get the right paint match and used non-catalyst clear and I am not one to brag but it looked flawless.
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Got a brand or pn that you use? The only non-catalyzed clear I can think of (leaving out the rattle can stuff) is an intercoat clear that is minimal build and designed as a protective layer for artwork/airbrushing so you can safely do tapeouts for the next layer of graphics. It offers no real protection to the elements to speak of, ie: no UV resistance. If this is what you are spraying, using this stuff as a topcoat with no UV protection, I would be concerned about how long it would last and having to do rework. | | | | | Joined: Jan 2012 Posts: 24 New Guy | | New Guy Joined: Jan 2012 Posts: 24 | I'll have to look tomorrow at the can for a part number. The basecoat is PPG. I too, wonder about how long it lasts. I only use catalyzed on my stuff. The first time I used non catalyzed was on a couple old vending machines I restored for a guy in Colorado. I didn't know they did clear in a spray bomb? Can't imagine that stuff would do much?
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Long term durability is where a 2K clear wins. I've had fantastic results with this activate in the can 2K aerosol: http://www.spraymax.de/index.php?id=361&L=1
1952 1300 Canadian 1/2 ton restomod You Tube | | |
